5 members (Lightholder's Dad, Paul Mullen, Gray_Ghost, TUTS 59, Wally / Montana), 210 guests, and 2 robots.
Topics128,077
Posts1,056,019
Members48,433
my 46 chevy has rust through at the bottom of the windsheild where the rubber sits
how is that normally repaired?
Cut, bend, fit and weld.
Bruce
My Trucks
Stuff I Collect
Ex Hall Monitor
Ex Hall Monitor
To expand a bit on Bruce's post it's best to remove the rust and replace it with new metal. If you have the necessary skills you can do it yourself. If in doubt hire a pro.
Do a search here; you will find several posts and pictures showing the process. It ain't easy...
~Jim
if its a pit it can be filled if its a hole cut and weld
If all you have is pin holes, you could clean it up, paint it and apply seam sealer to fill the area. It is really strong and stable.
1951 1 Ton Completed
