7 members (1955 1 Series, cmayna, Gray_Ghost, JW51, Pete1946, 55shaker, 1 invisible),
157
Mod | | | Forums66 Topics128,070 Posts1,055,900 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | my 46 chevy has rust through at the bottom of the windsheild where the rubber sits how is that normally repaired? | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Cut, bend, fit and weld.
Bruce | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | To expand a bit on Bruce's post it's best to remove the rust and replace it with new metal. If you have the necessary skills you can do it yourself. If in doubt hire a pro.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Do a search here; you will find several posts and pictures showing the process. It ain't easy...
~Jim
| | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | if its a pit it can be filled if its a hole cut and weld | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If all you have is pin holes, you could clean it up, paint it and apply seam sealer to fill the area. It is really strong and stable. | | |
