| | | Forums66 Topics128,277 Posts1,058,443 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 23 Apprentice | | Apprentice Joined: Feb 2008 Posts: 23 | I bought my Burb a few months ago, the previous owner said it had a 250 six but did'nt have anymore info than that. It has electronic ignition, the numbers to the left of the distributor reads; CON2 K 196 377127 GM. I haven't been able to find anything similar on the internet. | | | | | Joined: Mar 2008 Posts: 11 New Guy | | New Guy Joined: Mar 2008 Posts: 11 | check the head#,of course you need to know what year it is...good luck..bob | | | | | Joined: Feb 2008 Posts: 23 Apprentice | | Apprentice Joined: Feb 2008 Posts: 23 | The Suburban was built November of 1950, like I said the previous owner said he "thought" it was a 250cid straight six with solid state ignition, are there any engine design clues that might help in determining what engine I've got. I need to do some repairs to the engine but I don't know what to order regarding engine displacement and year, any help is always appreciated! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | How many screws/bolts hold the valve cover to the head?
2 nuts on the top of the valve cover = 1953 or earlier 216/235.
4 screws/bolts on the edge of the valve cover = 1954-62 235/261
A 230, 250, and 292 would have (I think) more than 4 screws holding the valve cover to the head.
There are other distinguishing characteristics but the above information will get you closer.
The block casting number is at the upper right of the starter. The engine ID (serial number) is pressed into the block just to the rear of where the distributor enters the block. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | The easiest identifying characteristic is the location of the Distributer. The 216, 235 and the 261 have their distributer located on the passenger side about the middle and the 194, 230,250 and the 292 have it located towards the water pump. Here's a list of casting numbers that you can look for. ENGINE IDENTIFICATION | | | | | Joined: Feb 2008 Posts: 23 Apprentice | | Apprentice Joined: Feb 2008 Posts: 23 | That's It! I knew somebody would come through! So per the Engine ID# I have a 73-79 Chevy 250cid.
Thanks GMONIZ !! | | |
