1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40218 11/12/2004 12:42 AM | Joined: Nov 2004 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 121 | I am having quite a time with my carb. I rebuilt it several weeks ago and it worked fine. A few days ago it started flooding and I am unsure why. I have disassembled it again, bought another kit for it from NAPA this time and really can't find anything wrong. The only thing I think it might be is the holes where the pin slips through for the float pivot point are very badly worn. I am wondering if the excessive slop might allow the float to get twisted on the side of the bowl and not shut off the needle. Any thoughts on this, or if this could be the problem, how to correct? I was thinking of using epoxy glue and glueing the pin to the worn holes. It would be difficult to remove the pin in the future if one were to do this, but I have to get it fixed. This carb is on a 63 292 Chevrolet grain truck that is still used during harvest. Any advice appreciated. | | |
#40219 11/12/2004 1:52 AM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | If the float shaft support holes are badly worn oblong; you would be better served to either replace the float, or replace the damaged portion of the float.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
