Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Sjm, Dakota Bob, Wally / Montana), 104 guests, and 3 robots.
Topics128,275
Posts1,058,439
Members48,490
#401856 04/14/2008 1:41 AM
Apprentice
Apprentice
I bought my Burb a few months ago, the previous owner said it had a 250 six but did'nt have anymore info than that. It has electronic ignition, the numbers to the left of the distributor reads; CON2 K 196 377127 GM. I haven't been able to find anything similar on the internet.
check the head#,of course you need to know what year it is...good luck..bob
Apprentice
Apprentice
The Suburban was built November of 1950, like I said the previous owner said he "thought" it was a 250cid straight six with solid state ignition, are there any engine design clues that might help in determining what engine I've got. I need to do some repairs to the engine but I don't know what to order regarding engine displacement and year, any help is always appreciated!
How many screws/bolts hold the valve cover to the head?
2 nuts on the top of the valve cover = 1953 or earlier 216/235.
4 screws/bolts on the edge of the valve cover = 1954-62 235/261
A 230, 250, and 292 would have (I think) more than 4 screws holding the valve cover to the head.
There are other distinguishing characteristics but the above information will get you closer.
The block casting number is at the upper right of the starter. The engine ID (serial number) is pressed into the block just to the rear of where the distributor enters the block.
The easiest identifying characteristic is the location of the Distributer. The 216, 235 and the 261 have their distributer located on the passenger side about the middle and the 194, 230,250 and the 292 have it located towards the water pump.
Here's a list of casting numbers that you can look for. ENGINE IDENTIFICATION
Apprentice
Apprentice
That's It! I knew somebody would come through! So per the Engine ID# I have a 73-79 Chevy 250cid.
Thanks GMONIZ !!
