4 members (Bill Hanlon, Otto Skorzeny, gswbbc, dt235sd), 83 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#40216 07/21/2003 3:00 PM
I have just finished my new old 235 in my new old 53. Right now I still have the original trans, and closed driveshaft. I refilled the trans with fluid and have the u-joint housing open because I still have to replace a retaining bolt in the u joint. Anyway, while getting the engine running right the trans was turning and trans fluid was running out where the u joint slips in. My question is..... Is there supposed to be a gasket of some sort that would keep the fluid from running into where the u joint is? Or is there supposed to be fluid in around the u joint too? Thanks
1953 Chevy 3100
The Green Truck
#40217 07/21/2003 3:30 PM
As you have observed, the transmission fluid also lubricates the enclosed u-joint (on 3 and 4 speed enclosed-driveshaft transmissions).
