| | | Forums66 Topics128,049 Posts1,055,552 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 5 New Guy | | New Guy Joined: Apr 2008 Posts: 5 | first time painting, was wondering what 'allow each coat to flash until hand slick' means. Thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | mikes1952,
I would it interpret it mean the surface is 'dry to the touch'. This doesn't mean it is totally cured or dry full depth.
Sometimes manufacuter's want the foundation coat only partially dry so that the solvent in the following coat allows it to 'melt' into the first coat. I'm not a professional painter, so this might be bum info.
Stuart | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Hand slick means your hand doesn't drag on it when you run it over it lightly, but not so dry that you can't leave a finger print in it if you really try.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | What he said....  Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Apr 2008 Posts: 5 New Guy | | New Guy Joined: Apr 2008 Posts: 5 | thanks guys, this is the big weekend, fingers crossed. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Just remember, if you don't post pics it never happened.
Best of luck.
