| | | Forums66 Topics128,105 Posts1,056,205 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40178 02/11/2005 5:53 PM | Joined: Feb 2005 Posts: 2 Junior Member | | Junior Member Joined: Feb 2005 Posts: 2 | Trouble shooting a 2speed electric rear end. It will not shift from low to high range. Anybody know how to test the motor in the 2 speed unit to see if it is good,or what else might be wrong? secon@cqservices.com | | |
#40179 02/13/2005 8:29 AM | Joined: Sep 2003 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 23 | I'll go check My manual for my 56 GMC. I don't remember seeing too much difference in the motors for the different types. Do you know what type you have of hand?
#40180 02/14/2005 2:49 AM | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | Two speeds are fairly straightforward to troubleshoot. Without the engine running and the ignition switch on, move the two speed switch and listen for the motor on the rear axle. Right after you switch from high to low (or vice versa), you should hear the motor run for a couple seconds and then quit. If you don't hear anything, the first place I would start is the switch. If you unplug the wires going to the switch, you should have one wire with 12 volts. If you have 12 volts to the switch, plug the wires back into the switch and see if there is voltage leaving the switch. Flip the switch back and forth to see if voltage goes from one outbound wire to the other. IF all this checks, the switch is good. Next verify that each wire going to the two speed itself is getting fed when the switch is actuated.
Next step is to remove the cover on the two speed motor. Inside you will see a screw driven by the motor. The motor turns the screw which shifts the axle by moving the lever attached to the 'nut' on the threaded shaft. At the top and bottom of the threaded shaft is a 'knife switch' which opens the circuit when the shift lever has moved the correct distance when shifting. On the back side of the 'nut' is a nylon tip that sticks out to actuate the knife switch. Sometimes the tip breaks off and will not allow the motor to operate. For example, when the switch is in the down position, the knife switch opens one set of contacts, shutting the motor off. When the motor calls to run in the other direction, another set of contacts allows the motor to reverse. Many times these switch contacts fail. Parts for these units are available from medium and heavy duty truck parts houses.
Anybody else jump in with anything I missed! | | |
#40181 02/14/2005 3:55 AM | Joined: Sep 2003 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 23 | Pretty much what he said. If you want, I'll photocopy the Electric shift portion of the factory manual. It's about 12 pages. I could also scan it and send it to you in a PDF. It has a toubleshooting guide as well as some good diagrams on the internals.
