5 members (51sub, Stovebolt48, carbking, Wayne67vert, 1 invisible), 51 guests, and 1 robot.
Topics128,041
Posts1,055,593
#401083 04/12/2008 1:10 AM
Apprentice
Apprentice
i have a 58 apache truck... it has a two speed electric motor (window washer)under dash. arms are not connected . will stock arms work??? if so where do i get the bushings to fit electric motor with stock arms
thanks doug
gina #401096 04/12/2008 1:38 AM
if it's the original 58 elec motor [which didn't have a washer function], it and the arms will look like this ... if it originally had vacuum wipers, might have different arms .... not sure what you mean by 'bushings', the arms should fit on the pins that are part of the motor assembly
Flxible #401106 04/12/2008 2:17 AM
Hey red - bad link. What happened? headscratch
oops, I took it too far - try this, click "full size" on the right of the thumbnails
Flxible #401121 04/12/2008 2:47 AM
Thanks!
Apprentice
Apprentice
the wiper arms are completely different then in the picture...where the arm fits on the motor it seems there has to be a bushing...i really appreciate all the info everyone has helped with thanks doug
gina #401711 04/13/2008 7:37 PM
jdl Offline
Are you sure that you don't have vacuum wipers?
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #401746 04/13/2008 8:31 PM
Apprentice
Apprentice
it's an electric delco motor 2 speed from rochester ny... maybe some might know where i can get parts??thanks doug
gina #401784 04/13/2008 9:54 PM
Sounds to me like you may have an aftermarket. If so, most of the suppliers should have some to fit.
Robert C.
I'm a Genius in the making.
1950 3600
