0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 18 Junior Member | | Junior Member Joined: Nov 2002 Posts: 18 | I just bought a 70 chevy with 72k miles on it. I pick it up on valentine's day, and the first thing I am going to do is tune it up and change the oil. I welcome any advice as to how to go about restoring this truck's motor, What to do first etc... Thanks | | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | An oil change would probably be the most beneficial thing to do. I would also flush the braking system unless the previous owner has done so. Inspect all the brake hoses and lines, and the condition of the wheel cylinders and master cylinder.
On to the motor: Check the coolant and condition of the radiator and radiator hoses. You probably want to do a system flush just for good measure, unless the previous owner recently did so. Also plan on changing fuel and air filters, the spark plugs, points and condensor. Once fired I'd let the engine run 5 minutes then drive it, if possible. After it runs warm listen closely for lifter noise - could be a bad lifter or cam.
I'm sure others will add more but these should get you off to a good start at minimum cost.
-ftyler | | |
