2 members (Chip O, Hotrod Lincoln), 140 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
#40157 05/23/2002 9:22 PM
My 3/4 ton Chevy has a set of fixed springs mounted on top of the standard bottom set. In my factory manual, I see these were installed only on heavier models, not on the 3/4 ton. What's the story? I also removed the two chassis brackets that contact the upper fixed springs when they are compressed, but I can't figure out where they go now that I've blasted the frame. Anyone with pix out there of this setup? Thanks!
#40158 05/23/2002 9:44 PM
I have a set of those on my half ton, but they contact the frame directly when there is more than 500 lbs in the bed, so I don't know where your brackets go, but I bet if you put a 500 lb load in the bed and put the brackets wherever the ends of the springs are near the frame that is good enough.
Paint & Body Shop moderator
#40159 05/23/2002 11:46 PM
OK, thanks! Just wanted to know what I was doing......
#40160 05/24/2002 3:27 AM
Anonymous
Unregistered
Anonymous
Unregistered
Those extra springs are called overloads. When the load carrying capicity of the truck is met [ more than 500 lbs.] the overloads kick in. In some states the cops will stop you if the overloads are riding on the stops.
