1 members (baldeagle), 108 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#40153 05/25/2002 7:12 PM
Help guys, the WARDEN is gonna kill me if I don't get her car fixed. It's a 95 camaro,3.4 v6, the check engine light keeps coming on, the so called mechanic that worked on it changed the EGR valve, it is electric and expensive $379.00 from GM. It still comes on and sets the same code, If I remember what he said it was a code #40, however I looked that up in a book and it says power steering pressure switch cicuit fault. Any Ideas?He has had three opportunities to fix it and I'm getting tired of the WARDEN giving me h-ll about it.
Today is my birthday and I was promised a nice dinner at place of my choosing,(lot of good food down here in New Orleans) but was told if I don't get the car fixed I will be taken to B&K Steak house( burger king). HELP I want some good food. eek frown :confused:
Tommy
59 apache 1/2t
261 short stepside
#40154 05/26/2002 2:06 AM
I'd go see the parts changer that put a $400 dollar part on my engine that still has the same problem and demand my money back. Just because a code sets does not mean a part is defective, it simply means the computer has seen a problem on that particular circuit. More testing is needed.
Cant help you with the diagnostics (at home, info at work) but if it is a egr code (and gm has trouble with them) go ahead and drive it until you can get it fixed.
#40155 05/26/2002 2:57 PM
Curly, still driving it, runs fine. the code was a #77 digital egr #3 soleniod cicuit fault.He's getting it back wednesday. I was just wondering, the battery died friday and had to be replaced, only 2 1/2 yrs old, could that have anything to do with it? Or maybe a sensor on the engine, there are so many you don't know where to start looking.
Tommy
59 apache 1/2t
261 short stepside
#40156 05/26/2002 4:10 PM
Tommy,You say it runs well? Sometimes false codes are set by loose or corroded engine grounds.Some models have several small computer grounds on the thermostat housing bolt, usually a bad connection there. A bad battery, internally shorted may start the engine but not allow the proper charging system voltage ,setting off codes.The computer recieves a signal from the egr valve on a timed basis, if the computer thinks the egr is malfunctioning, it sets a code.If the egr exhaust passages are plugged with carbon(common)the code will set even if the valve is ok.If all else fails, a piece of tape over the check engine light can bring peace of mind.
