| | | Forums66 Topics128,064 Posts1,055,861 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 54 Member | | Member Joined: Jun 2003 Posts: 54 | Just a little background-----our 61 Apache C20 has been sitting in a field for over 8 years and we are just beginning to restore her. We've completely redone the brakes and replaced all of the brake lines. Also replaced the line from the master cylinder to the slave cylinder and put in a new slave cylinder. I seem to be able to feel the gears when the clutch is depressed however can't seem to get her in neutral. When we push her around the drive shaft rotates. Any thoughts on getting into neutral without taking the clutch apart? We are going to work on the clutch later, but for now just want to get her running.
Thanks!
Not quite as lean Not quite as mean, but Still a Marine!
