2 members (216wny, Hotrod Lincoln), 68 guests, and 2 robots.
Topics128,036
Posts1,055,458
Members48,422
#401016 04/11/2008 9:02 PM
Is it possible to install the hinge springs on a AD series without removing the hinge pin? I think I did it years ago on another truck. But I'm looking at mine now and I don't see how it is possible. Cleon
1949 Chevy 6400
1931 Chevy Firetruck
31,32,33 #401407 04/13/2008 1:17 AM
I dunno, Cleon. I just did mine a few weeks ago, and I had to take out the hinges.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Tom R #407640 04/28/2008 11:56 PM
yes it is possible
BUT you have to remove the hinge from the truck
you can whack it in but you may damage it
pushing out the pin ALSO ALLOWS you to lubricate the pin,
clean the oil hole for future spray grease & inspect the whole shebang
IF you do it right, you won't regret the time spent .
Jim & Caroline
