7 members (Forty9, RdsLessTaken, Hanks custodian, mick53, cmayna, Nick in Manitou, 1 invisible),
82
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,264 Posts1,058,356 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40126 09/11/2002 10:08 PM | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | I'm replacing the original carb (1-barrel Rochester on 53 Chevy 216) with a rebuilt. Vendor says no gaskets are needed; carb just sits on insulator and there's also no gasket between insulator and manifold. 1. Is that correct? 2. Anybody have a torque setting for tightening down the carb on the manifold studs? Don't want to crack the insulator. 3. What should I use on the threads for fuel and vacuum line fittings to seal? | | |
#40127 09/12/2002 12:44 AM | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | I can't remember about the gasket question but the vacuum line seals with a flare fitting, so no sealant is required. | | |
#40128 09/12/2002 12:50 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I suggest using a gasket above and below the insulator.Best to avoid possibilities of vacuum leaks
