3 members (Joe H, Gdads51, UtahYork), 99 guests, and 2 robots.
Topics128,264
Posts1,058,355
Members48,485
#40126 09/11/2002 10:08 PM
I'm replacing the original carb (1-barrel Rochester on 53 Chevy 216) with a rebuilt. Vendor says no gaskets are needed; carb just sits on insulator and there's also no gasket between insulator and manifold.
1. Is that correct?
2. Anybody have a torque setting for tightening down the carb on the manifold studs? Don't want to crack the insulator.
3. What should I use on the threads for fuel and vacuum line fittings to seal?
#40127 09/12/2002 12:44 AM
I can't remember about the gasket question but the vacuum line seals with a flare fitting, so no sealant is required.
1951 1 Ton Completed
#40128 09/12/2002 12:50 AM
I suggest using a gasket above and below the insulator.Best to avoid possibilities of vacuum leaks smile
