2 members (Jay R, Donf),
71
Mod | | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 31 Apprentice | | Apprentice Joined: Nov 2007 Posts: 31 | i have a 58 apache truck... it has a two speed electric motor (window washer)under dash. arms are not connected . will stock arms work??? if so where do i get the bushings to fit electric motor with stock arms thanks doug | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if it's the original 58 elec motor [which didn't have a washer function], it and the arms will look like this ... if it originally had vacuum wipers, might have different arms .... not sure what you mean by 'bushings', the arms should fit on the pins that are part of the motor assembly Bill | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | Hey red - bad link. What happened?  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | oops, I took it too far - try this, click "full size" on the right of the thumbnails Bill | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | | | | | | Joined: Nov 2007 Posts: 31 Apprentice | | Apprentice Joined: Nov 2007 Posts: 31 | the wiper arms are completely different then in the picture...where the arm fits on the motor it seems there has to be a bushing...i really appreciate all the info everyone has helped with thanks doug | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Are you sure that you don't have vacuum wipers? | | | | | Joined: Nov 2007 Posts: 31 Apprentice | | Apprentice Joined: Nov 2007 Posts: 31 | it's an electric delco motor 2 speed from rochester ny... maybe some might know where i can get parts??thanks doug | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Sounds to me like you may have an aftermarket. If so, most of the suppliers should have some to fit.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | |
