2 members (Rusty Rod, LAROKE), 103 guests, and 3 robots.
Topics128,193
Posts1,057,260
Members48,466
Junior Member
Junior Member
Any one in the Seattle/Tacoma area have any recommended (or not) shops that they have used to get their gas tank reconditioned? Is it even worth it? I would like to have increased capacity, but retain the stock location (under bed) on my 48 3600, but haven't seen a good solution.
Fabled48
I can't drive 55... no really, I can't!
Hey Fabled48,
I don't know about the Seattle/Tacoma area but splashoil just told me the other night he uses a radiator shop in Bellingham called Whatcom Radiator for cleaning and sealing the gas tank. You may want to call around to a few radiator shops.
Dave cool
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless!
My 1962 Chevy C-30
Red dot, center of chest ...
Your local radiator shop should be able to do the job for you. That's where I had mine done, and they did a fine job.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Ken, the owner of Whatcom Radiator in Bellingham, WA does an excellent job of reconditioning gas tanks. He does request if it is exceptionally dirty to take it to a car wash and give it a blast of hot water first to get the heavy stuff off first. Then it goes into his hot tank full of caustic solution for a long cook. Out of there, he inspects the tank carefully to make sure it is cleaned good enough. If not, it goes back in for a second bath. When the tank is cooking in the vat, varnish fumes are very strong as they flash out of it.
He then dries the tank thoroughly, using a hair dryer to move warm air through it. Once it is dry he then uses the tank liner solution to slosh the inside with alchohol resistant sealer. I believe most tanks get a couple coats. I have also brought in my gas filler pipe, wiring it to the tank so it goes along for the treatment.
I don't know of any shops in the Seattle area that do this, but I would imagine there must be some. Remember, an old timer told me many years ago a good radiator shop can make you or break you. Be sure to talk over the process with the shop to make sure they will do a good job and maybe look at tanks that have been cleaned and lined at the shop. This is a very good investment IMO. wink
