2 members (Uncles51, Shardean), 50 guests, and 4 robots.
Topics128,021
Posts1,055,356
Members48,420
#400974 04/11/2008 6:12 PM
Apprentice
Apprentice
I am in the process of buying a '49 1/2 ton panel from a gentleman who swears that one window inserted behind the doors on each side were rare, add-on dealer options purchased when the truck was new.
I'm not buying the truck for the windows, and I plan to fill them in but I had never heard of these "options" before. I suspect that the dealer back then had an opportunity to sell the windows as accessories back in the day, but I'm wondering if there is anything to this story of a "rare" add-on window option...?
51 1/2 ton-455 rocket!
49 1/2 ton panel-rocket-to-be!
don't know if you'd call it an option, especially from the dealer, but it was possible to special order them from the factory - I had a 57 panel ordered for use as an ambulance that they put windows in, documented by a restopak for the vin#
A dealer could add on any "option".
The window you describe on the '49 was not a GM factory option.
1 Offline
post some pic's of your panel
Apprentice
Apprentice
I drove to Indianpolis yesterday (from southern Ohio) and bought my long-sought-after panel truck--YAY! I'l try to post some pictures in the next few days...
The seller again mentioned how rare the "factory" extra side windows were. I looked real close at one of the windows, and stenciled down in the lower right corner were the words, "FoMoCo". I didn't say anything... I bought the truck, loaded it up and headed home. The gentleman and his friends who helped load everything were real nice and I believe, very sincere. But it just shows that you can't believe everything that you're told--and to check things out.
He also handed me an incorrect title. The numbers didn't match the truck. He was flustered and went back to his house and dug through some stuff for a while and finally found the right title.
I had no issues on the way home...(250 mile drive-one way)
Rockettruck
Joe,
Were the OEM windshields that you have seen been marked L-O-F (Libbey-Owns-Ford, which has been owned by Pilkington since 1985), FoMoCo (Ford Motor Company), or Ford Glass Company (maybe the Edward Ford Plate Glass Company, which became the "F" in L-O-F around 1930)?
My 1950's glass is usually marked L-O-F (I guess this was the marking L-O-F put on OEM GM glass at that time).
Tim
The "F" in L-O-F (Libbey-Owens-Ford) was not one of the FoMoCo Fords.
However, it is interesting that the L-O-F Ford (John Baptiste Ford) started PPG, and later left PPG to form the Ford Glass Company (not related to FoMoCo). Ford Glass Company merged with Libbey-Owens Glass to form L-O-F.
L-O-F was much later bought by Pilkington Glass.
