| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40097 12/22/2004 10:44 PM | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Hi Guys and gals, I got my front disc conversion kit on my 49 GMC 1/2 ton last night. Went from 16, 6 bolt, to 15, 5 bolt pattern. Question is. What size tires can I go to safely without having rubbing problems? I was thinking of getting some 215/60R15s. Would they work okay?
kskt4 | | |
#40098 12/22/2004 10:56 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | It probably depends on the disk kit you used, but I'm now running BF Goodrich TA Radial 235-70/15 on 8 x 15 wheels on my '55 1st GMC.
216/60s should be even easier to fit since they are not as wide and not as tall.
Mine are the same size wheels and tires I ran before the conversion (I did swap wheels), and it appears my conversion moved the tires outward a fraction of an inch.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#40099 12/23/2004 1:51 AM | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Thanks OldSub, I got the kit from ECI.
kskt4 | | |
#40100 12/23/2004 3:20 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | My kit came from ChevyDuty. I asked them how it would impact track width. You might ask ECI about your kit.
