| | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40089 01/08/2005 11:43 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Okay, I pulled the motor out of my 46 half-ton this afternoon. I pulled it from the bell-housing forward, leaving the 4-speed tranny in place. My question; When I pulled the inner/lower bolts between the bell-housing and the tranny, gear lube began running out.
It seems to be about a half a pint or so.
Is this normal? This is my first experience separating the trans. from the motor. I would have thought there would be some type of seal that would retain the fluid in the transmission.
How much %wise did I lose, and do I need to do anything after I put the new motor in, that is besides the obvious topping off the gear lube? | | |
#40090 01/09/2005 12:36 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Gear oil ran out of the bolt hole? Yup, the threaded holes are open into the case. I think it's best drain out the old oil and clean out the threaded holes with spray brake cleaner.Use the white teflon sealer in a tube to coat the bolt threads on reassembly.One less place for oil to leak.Pull the front retainer on the tranny input shaft,no seal but you can put sealer on those bolt holes and on the gasket that should stuck on the case.While you're at it,do the pto side cover too,make your own gasket if necessary or use a RTV sealer.Gone this far,back off the nut on the rear yoke............ | | |
