| | | Forums66 Topics128,214 Posts1,057,488 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 20 Apprentice | | Apprentice Joined: Mar 2008 Posts: 20 | I'm building a new box assy. and having a little trouble w/placement of the two middle cross sills ! I find they line up with the holes in the metal strips at 23 1/8" and 50" from the front panel. Although they would not be bolted through the angle strips, as they don't line up . Am I on the right track ? My cross sills have no holes drilled in them so it makes it a little harder to figure out . Thanks for any help ,Mark | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | On a 47-51 1st short step you should have cross sills at the following locations: One at the 1st hole in the bed strips One at the 3rd hole in the bed strips One at the 5th hole in the bed strips A rear cross sill at the back. The angles are offset 7/8" to 1" to the rear of the truck The 4th hole back (on the angle) does not line up with the bed strips. Hope this helps. | | |
