| | | Forums66 Topics128,113 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40005 03/26/2003 4:37 AM | Joined: Dec 2002 Posts: 5 Member | | Member Joined: Dec 2002 Posts: 5 | I hope someone can help me id this transmission that I just picked up. I was lookin for a 5 speed t5 to put in my 54 chevy pu and ran into a guy that said he had one. The price was right so now that I have it home Im trying to id it from all the info i have found on the net about t5's but nothing jives that i can find. The tag under a bold head on the right side is numbered 104885. There are casting no's on all sides of the aluminum housing.The shifter is on top at the back of the tail shaft and the no. is 13-38-066-901. One on the left side is 13-38-007-901. One on the bottom left is 13-38-065-901. There is also a little round spot that looks like a dating mark and the numbers in it are 6 then 75. Im guessing it was made in june of 75, but can't find any info on any of the other numbers.??  Any help would be really appreciated. Thanks | | |
#40006 03/26/2003 8:39 AM | Joined: Nov 2002 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2002 Posts: 48 | I think it's borg warrner anyway. go to 4speeds.com and yiou can look up your tranny their site has 5 speeds to and is awsome!
If you need a tool and don't buy it, you will find you have paid for it and don't have it.
#40007 03/26/2003 1:43 PM | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | Most of the GM S10 T5s are listed at Inliners but the numbers you list are from something else. You may have a T50, which is a basically worthless,lightweight early 5-speed probably from a Chevette. | | |
