2 members (Ponchogl, Gdads51),
98
Mod | | | Forums66 Topics128,128 Posts1,056,670 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 8 New Guy | | New Guy Joined: Mar 2008 Posts: 8 | Stovebolters!!! I'm preparing to convert my '54 Suburban to open driveline and want some input to ensure I'm not dropping the ball, I hate doing things twice!!!
My sub is equipped with a 235 and my plan is to put a saginaw 4spd behind it (recommended by Patricks) then a new driveshaft and a chevy 10 bolt with 6 lug pattern at the rear.
I got the tranny from a friend who had it in his '51 5 window. I don't know much about it other than it's the same width as mine and it's a six lug. I'm going to have it checked out before I install it to check the gearing ratio but just want to be sure I'm going about this properly.
Any input would be appreciated. Thank you | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Something to remember is that the center bolt for the rear springs is located forward on the closed drive springs of where they are on the open drive springs. | | | | | Joined: Mar 2008 Posts: 8 New Guy | | New Guy Joined: Mar 2008 Posts: 8 | Got it. I forgot to mention new springs all the way around.
Dirty | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | While you have it apart replace the flexible brake hose and if there is any question replace the hard lines too.
Don't be surprised if your speedometer is off after the swap.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A six lug tranny? How interesting. | | | | | Joined: Mar 2008 Posts: 8 New Guy | | New Guy Joined: Mar 2008 Posts: 8 | Ya it's the newest thing.....my error, guess I should learn to proof read.
Dirty | | | | | Joined: Mar 2008 Posts: 13 New Guy | | New Guy Joined: Mar 2008 Posts: 13 | Hey Cletis , Good Morning. Im a 57 year old "beginner" on trk restoring - and been reading alot of archives here when i noticed ur in parker county - I live betwen weatherford and Brock. I've got a 53 1/2 ton commercial that im trying to do a frame off restore on. I know weatherford has a car club but havent meet anybody yet,are you in it? Do you have a steering wheel puller for a chevy? ha ha ha :o) | | | | | Joined: Mar 2008 Posts: 8 New Guy | | New Guy Joined: Mar 2008 Posts: 8 | Well guys, the rear end I had secured for the open driveline conversion is a no go so I'm looking for some further input on what rear end to grab.
So far, I've heard '82-up S-10 rear ends will work, 70-81 Camaro/ Firebirds, and 75-79 Novas.
I'd like to have a gear ratio of 3.55 or higher since I'm running the Saginaw 4spd and not a 5 spd.
I've also heard there's a Toyota rear end that some folks are using.
So any input you could give me would be greatly appreciated as my suburban is currently on the lift at a local shop apart and taking up space.
Dirty | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Dirty; Check out the late 60's Chevy half-ton rear ends. You can stay with 6 lugs that way and many of them had a 3:08 gear set. | | | | | Joined: Mar 2008 Posts: 8 New Guy | | New Guy Joined: Mar 2008 Posts: 8 | Thanks Waldo, I'll look into that.
Dirty | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | toyota 4x4 has 6 lug and they are strong rearends with axle dia. larger than a ford 9" | | | | | Joined: Mar 2008 Posts: 8 New Guy | | New Guy Joined: Mar 2008 Posts: 8 | Any idea what Toyota rear end is applicable?
| | | | | Joined: Dec 2007 Posts: 11 New Guy | | New Guy Joined: Dec 2007 Posts: 11 | I put a 2002 for explorer 8.8 - 3L73 posi traction on mi is strong like 9" rear and you can found in the junkyard, if you need more info let me now. | | |
