4 members (Shaffer's1950, Otto Skorzeny, Lightholder's Dad, 1 invisible), 207 guests, and 7 robots.
Topics128,088
Posts1,056,122
Members48,435
#397344 04/03/2008 9:23 PM
The horns on my 6400 are mounted on the firewall with the relay underneath. The assembly manual show the horns mounted on the radiator support. But the drawing is dated 6-29-53 so it may not apply to a '49.There are no holes on my support to mount them.
Can anyone with a '49 show me the correct location and horns, as these may not even be the correct ones. Picture below. Cleon
http://inlinethumb06.webshots.com/38341/2060976230098468599S600x600Q85.jpg
1949 Chevy 6400
1931 Chevy Firetruck
They look correct and I've seen horns mounted there before. I've also seen them mounted on the manifold but that was a single horn. You have both a high and low note horn. Possibly this is where they go when it's optioned that way? Somebody smarter than me will let you know for sure.
Bruce
My Trucks
Stuff I Collect
Looks about right to me - for 1949 (maybe they should be mounted a little higher - see the link below)
Say "thank you" once agai...ssory dual-horn installation instruction
Ok, It looks like some one lowered them by mounting them on a piece of flat stock and bolted them back up to the firewall in the original holes. I wonder why?. Maybe to clear the heater hoses? Thanks for the info. Cleon
1949 Chevy 6400
Apprentice
Apprentice
different horn(s) but same location as my '49
don't let fear and common sense stop you
'49 Chev AD 2 ton
http://i60.photobucket.com/albums/h37/rippintare/SUC52849.jpg
