1 members (1 invisible), 46 guests, and 2 robots.
Topics128,043
Posts1,055,610
#399156 04/07/2008 9:33 PM
Apprentice
Apprentice
I found a pair of 56 chevy brake drums that came off a car. The brake drums come with the spindals. Will the spindles hook up to my truck? It is a 56 3200 chevy.
Thanks kevin
kevint #399162 04/07/2008 9:51 PM
Riding in the Passing Lane
The car has 5 lugs & the truck has 6.
1972 Chevy c10 Cheyenne Super
Apprentice
Apprentice
I want the 5 lug. The reason I need new drums and hubs is because I had my old drums changed to 5 lug but the drums got bent when pressing in the new lugs, so now they are junk.
kevint #399233 04/08/2008 12:51 AM
The car has ball joints and the truck has king pins. They will not interchange. If your 5 lug hubs are ok you can use the drums.
Fred
rfs56trk #399642 04/08/2008 8:06 PM
Apprentice
Apprentice
I just figured out that the front and rear drums are the same except for the hub. Tonight I will grind the front hubs out and use the rear for the front if the hubs aren't bent. I think just the drums are bent. Thanks everyone for the help. I hope after i'm doing this for awhile I will be able to help someone else out. Kevin
