3 members (32Fordpuchoptop, Hotrod Lincoln, 1 invisible), 82 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#399065 04/07/2008 5:47 PM
Apprentice
Apprentice
I have looked in all my books but can't find a disk brake conversion kit for my 56 3200 chevy truck. Can anyone direct me to a place to buy one.
Thank you kevin
kevint #399074 04/07/2008 6:03 PM
The 3200 is a long wheel base 3100. It uses the same front axle as the 3100.
Hi kevint,I've found a company that list a disc brake conversion for your '56' The only downside is you will need to convert to 5 bolt wheels. I tried a link the other night,but as i'm a technophobe it might not work so here goes!http://www.mpbrakes.com/products/product-detail.cfm?product_id=443
I believe the part # is DB1753B
I hope this points you in the right direction good luck! thumbs_up
More pix on Flickr.
jockbolter50 #399168 04/07/2008 10:01 PM
I guess it didn't work! You'll just need to type it in the 'old fashioned' way!
I bought a dual circuit booster and servo from them for my '50' and have been pleased with the quality and service from them!
Initially they screwed up the order and sent a booster for a F*rd Bronco! To their credit they rectified the problem within 7 days and I'm 3500miles away! grin
Plus I got to keep the Bronco one to sell on Ebay!
More pix on Flickr.
jockbolter50 #399269 04/08/2008 2:02 AM
Kevin, I put the CPP 6 lug kit on my 59 longbed. No problems other than the usual from the kit. There are plenty of threads about the little things required to make the kit fir properly. I think most venders sell the kit for $699 which includes power Master cylinder, rotors, callipers, pads, etc. You will likely need to upgrade the stock ball type bearings to roller bearings.
These guys have the 6 lug rotor kit that you can use with your stock wheels. It comes with all components including bearings.
It does not use the original hub like others.
www.abspowerbrake.com
fred
jockbolter50 #399593 04/08/2008 5:16 PM
For it to work properly you need to put a space inbetween the ! and the h
just helping out
drummin52 #399611 04/08/2008 5:51 PM
Thanks drummin52 I'll try that next time! thumbs_up
More pix on Flickr.
jockbolter50 #399878 04/09/2008 5:48 AM
fred, that looks a lot like the CPP kit. I don't see new bearings or hubs listed with the 6 lug kit under 55-59 chevy trucks.
rfs56trk #402428 04/15/2008 1:18 PM
Speedway is also carrying the kit quite cheap without the master cylinder conversion
http://www.speedwaymotors.com/m/967_1947-64-Pick-Up-Disc-Brake-Kits.html
It's CPP's kit, only speedway carry's it 125.00 cheaper. Rebuilt calipers in the kit. They just delivered mine.
