5 members (Otto Skorzeny, Wickedbass, Hanks custodian, 32Fordpuchoptop, Gdads51), 67 guests, and 2 robots.
Topics128,094
Posts1,056,048
Members48,433
#397994 04/05/2008 3:49 AM
Kip,
This 4400 and your 6500 share all the same sheet metal. The cabs are all the same from the 1/2 ton through 2-1/2 ton trucks from 1955 second series thru 1959. The only difference between the small trucks and the big thruck is the transmission inspection cover on the floor (bigger hole for the bigger trucks) and nobody see's that once the floor mat is installed. In your case they are more than likely identical. The frame rails and springs will be bigger on your 6500 as it has a higher GVW.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Hey Kip,
Do you own this truck or are you looking at it? I would love to but the metal thingy off the stake rack behind the rear window. It's the part you can look through from the cab. Let me know if it's available.
Bruce
My Trucks
Stuff I Collect
I may buy this truck for the cab if I do I will let you know from what I'm told its got a great 265 in it I have not tried to crank it yet though Kip
