3 members (78buckshot, klhansen, 1 invisible),
152
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 23 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 23 | | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Kip, This 4400 and your 6500 share all the same sheet metal. The cabs are all the same from the 1/2 ton through 2-1/2 ton trucks from 1955 second series thru 1959. The only difference between the small trucks and the big thruck is the transmission inspection cover on the floor (bigger hole for the bigger trucks) and nobody see's that once the floor mat is installed. In your case they are more than likely identical. The frame rails and springs will be bigger on your 6500 as it has a higher GVW. Mike B  | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Hey Kip, Do you own this truck or are you looking at it? I would love to but the metal thingy off the stake rack behind the rear window. It's the part you can look through from the cab. Let me know if it's available.
Bruce | | | | | Joined: Mar 2008 Posts: 23 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 23 | I may buy this truck for the cab if I do I will let you know from what I'm told its got a great 265 in it I have not tried to crank it yet though Kip | | |
