3 members (TexasA&M48Truck, Bill Hanlon, 52Carl), 94 guests, and 2 robots.
Topics128,094
Posts1,056,058
Members48,433
#39837 04/18/2004 5:38 AM
I have several good older carbs that I want to keep(never know). Are there any secrets to keeping them from freezing with varnish over time?
Thanks!
#39838 04/18/2004 1:53 PM
Good question. Rebuild the carb first, then put it in a zip lock air tight bag.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#39839 04/20/2004 8:04 PM
I'm not an expert. This is what I have done with my YF: removed top-housing, removed accel-pump, blew out all passages with compressed air until carb is quite dry and reassembled. The YF has a diapham-pump, if it had a leather pump, I think I'd put some light oil on it. Don
#39840 04/20/2004 8:12 PM
If you are going to rebuild it, wait until you take it out of storage. The gaskets dry up and shrink eventually.
Just drain it completely and wash it with rubbing alcohol to drive off the water and leftover solvents. Keep it dry and cool and it will be fine.
I drain my motorcycle carbs whenever I store it for more than a week and the gaskets are still the 1974 originals.
Paint & Body Shop moderator
#39841 04/21/2004 4:48 AM
Thanks for all the great answers! I Appreciate your help!
