3 members (Shardean, Ponchogl, dt235sd), 92 guests, and 3 robots.
Topics128,021
Posts1,055,349
Members48,420
#394934 03/29/2008 4:22 PM
Apprentice
Apprentice
i'm restoring my 49 p/u and need a fuse box either original or new style ,have replaced the wiring harness so i would like to stick w/the same type of connectors Thanks
mgebo52 #395091 03/29/2008 11:11 PM
Your 49 didn't come with a fuse box, just inline fuses. Do a search on here for what others have done. Are you installing a new wiring harness, if so it should come with one.
~Jim
BIG CHEVY 3600 #398127 04/05/2008 3:05 PM
Your 49 did not come with a fuse box. I've seen some univesal fuse blocks at Advance Auto and O'Reilly that would work well. They have one with Barrel Fuses that looks cool and would probably go with the nostalgia of the truck. You can also use a spade type fuse block and hide it.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #398133 04/05/2008 3:18 PM
Do all new harnesses come with fuse boxes?
None of my reproduction harnesses came with a 2-circuit fuse "box" (even for 1954, in which a fuse box is original equipment).
mgebo52,
What brand/vendor wiring harness did you use? If it was a reproduction harness, it would not come with a fuse box. If you are restoring to original "specs", as stated above, there was no fuse box in 1949 but you could add a fuse box. [This not correct: there was a standard 48-49 5-circuit fuse box - see below.]
Tim
tclederman #398144 04/05/2008 3:43 PM
Tim - I think all the harnesses sold as "xx circuits" come with a fuse box, ones sold as year "reproductions" won't because the fuse box wasn't originally part of the wiring .... I don't believe the fuse panel was actually "standard" when they first started using them, only added if the truck was getting optional [electrical] equipment .... that's the way it's been on every TF series truck I've seen, if they were the "base" model, no fuse panel, if elec wipers, or radio or etc, they had the fuse panel
Flxible #398152 04/05/2008 4:14 PM
Bill,
I know nothing about Task Force trucks, but I am surprised to hear there was no fuse box/block/panel/etc on standard production TF trucks.
I thought mgbo52 was talking about a 49 pickup.
A fuse "box" (two fuses and storage for 1 or 2 spare fuses) was standard on the firewall of all 1954 trucks but I do not know in what year that "box" became standard. I am fairly certain there was no standard fuse "box" in 1949, as stated by others above (I'll check this out, when I get home tonight). [There was a standard 48-49 5-circuit fuse box - see below.]
As I stated above, "None of my reproduction harnesses came with a fuse "box" (even for 1954, in which a fuse box is original equipment).
Tim
tclederman #398159 04/05/2008 4:36 PM
Tim - yes, I'm a little off topic grin
what are those 2 fuses for?
on the TF trucks, the lights are fused on/in the light switch, and there's nothing else that needs a fuse
this original TF fuse panel has 3 of the 7 slots used, and the truck [Steve Taylors 700 mile original '59] is equipped with radio, lighter and deluxe heater, any of which would have 'triggered' installing the panel [others are spotlamp, backup lamp, brakelamp(signals), wipers], beyond that it's just a junction block
I suppose it was a matter of saving a few cents for GM
Flxible #398177 04/05/2008 5:51 PM
The 2 fuses on '50 - '54 trucks were for the wiring going "out back". One for stop lights, and one for tail lights.
The Shop Manual for '48 - '51 trucks does indeed show a 5 slot fuse panel and cover for the '48 - '49 models. These were for:
1. High beam
2. Low beam
3. Park
4. Tail lights
5. Stop lights
waldo53 #398213 04/05/2008 7:58 PM
5-slot fuse panel for 48-49? Where was it mounted? Near the voltage regulator on the firewall (where the 2-fuse box is mounted in '54)?
tclederman #398216 04/05/2008 8:02 PM
Here's what the manual says:
(info in the lower left corner of this page)
http://chevy.tocmp.com/shop/1948_51truck/51ctsm1201.htm
So, looks to me like it should be about in the same place as the 2-fuse set-up on the later AD's.
waldo53 #398252 04/05/2008 9:46 PM
You are right, Waldo. I'll post a photo of the 48-49 5-circuit fuse box tomorrow, if no one else posts one by then.
tclederman #398270 04/05/2008 10:39 PM
so I guess the change from 5 to 2 was when they started using a different light switch with built in protection? then in 55 they must have decided the rear light fuses weren't necessary .... on the TF switch there's seperate bimetal links for tail/stop and head/park lights
Flxible #398320 04/06/2008 1:31 AM
As waldo53 described (thanks for the correction):
1948-1949 Advance-Design fuse box.
Tim
tclederman #398337 04/06/2008 2:14 AM
jdl Offline
Isn't there a fuse under the dash on the '54 too or is my truck just weird?
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #398369 04/06/2008 3:25 AM
JD - what you have is probably an inline fuse, commonly added with aftermarket equipment, like to power your non-stock radio
Flxible #398375 04/06/2008 3:35 AM
jdl Offline
Hmmm. That's a thought. The fuse is right below the guage cluster. It has a switch on it but I don't know what it's for.
Jordan D. Long
Photobucket
jdl #398378 04/06/2008 3:38 AM
That would most likely be the heater motor/blower control switch.
tclederman #398380 04/06/2008 3:44 AM
jdl Offline
Then what is the cable connected to the heater for? It goes to the knob right next to the fuse.
Jordan D. Long
Photobucket
jdl #398392 04/06/2008 4:11 AM
If you are referring to the black knob with a white indentation on the front of it, that is attached to a cable that opens the interior air door on the front of the Air Flow heater (if you have a that style of 54 heater). See if there is a word on the switch "lever" on the fused switch.
tclederman #398400 04/06/2008 4:25 AM
jdl Offline
Guess what it says... It says the same thing my radio says........ ATR! Now why would ATR be on the heater switch?
Jordan D. Long
Photobucket
jdl #398481 04/06/2008 1:31 PM
I have attached a picture of the fuse box on my truck. It has 5 fuses Hi Beam, Low Beam. Instrument Lights, Stop and Tail
http://inlinethumb40.webshots.com/21543/2537899640098468599S600x600Q85.jpg
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
tclederman #398603 04/06/2008 6:20 PM
Apprentice
Apprentice
yes thats the exact fuse box i need any idea where i can find one . And thanks for all the help . Mark
mgebo52 #398637 04/06/2008 7:23 PM
Post an ad in the Swap Meet - I think you'll only find a used one.
