| | | Forums66 Topics128,139 Posts1,056,756 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 14 New Guy | | New Guy Joined: Jan 2008 Posts: 14 | whats the difference between a 2 speed powerglide that goes with a L6 and one that goes with a V8? gearing? bolt pattern? Also how much does a powerglide weigh?
thanks -chris- | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Chris,the powerglides are the same.The only difference is the low gear ratio,V8:1.76,L6:1.92 The main hub is a V8 is machined steel,in the 6 it is stamped sheet metal[not as strong]Good for street use behind a V8. On the outside,you can't tell them apart.I think they must weigh about 60-80lbs, Boyd | | | | | Joined: Jan 2008 Posts: 14 New Guy | | New Guy Joined: Jan 2008 Posts: 14 | BC52,
thanks for your reply
thanks -chris- | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | There are two generations of Powerglide. If you are talking the old cast iron Powerglide there is an adapter ring that is specific to the six or eight.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Opps I wasn't even thinking of cast iron ones | | |
