0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 66 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 66 | I'm about ready to get the old blister on the road for the first time. I had a few leaks in all the drive train but I think I have them all fixed, well....lets see.
I wanted to ask what the recommended fluids are for the drive line. I believe the engine is a 235,tried to run the numbers but no luck, it doesn't have an oil filter, the transmission is a three speed, the rest is supposed to be stock for a 53.
What oils should I use for the engine,transmission and rear end ?
Your thoughts would be helpfull | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Use diesel oil in the engine, like Shell Rotella or equivalent. Use 80-90 gear lube in the gear boxes. GL-5 must be used in the rear end & can be used in the trans. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Well, this'll prolly stir up a hornets nest again - but - I went to Wallyworld today to get some oil for the ol' girl. All they carry now (at our store) is Rotella CJ-4, which is the "new" formulation. It actually has less ZDDP in it than the Castrol GTX 20-50w I've been using. According to the research I've done, you'll need to find the "old" CI-4 formulation to get more zinc than the Castrol GTX 20-50w. | | | | | Joined: Jul 2007 Posts: 66 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 66 | Okay thanks everyone.
I know that the Rotella T15-40 is a Shell product but, who makes the GL-5 for the rearend and transmission ? | | |
