0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#395458 03/30/2008 8:30 PM
I'm about ready to get the old blister on the road for the first time. I had a few leaks in all the drive train but I think I have them all fixed, well....lets see.
I wanted to ask what the recommended fluids are for the drive line. I believe the engine is a 235,tried to run the numbers but no luck, it doesn't have an oil filter, the transmission is a three speed, the rest is supposed to be stock for a 53.
What oils should I use for the engine,transmission and rear end ?
Your thoughts would be helpfull
Riding in the Passing Lane
Use diesel oil in the engine, like Shell Rotella or equivalent. Use 80-90 gear lube in the gear boxes. GL-5 must be used in the rear end & can be used in the trans.
1972 Chevy c10 Cheyenne Super
Yep. Rotella T 15-40
1951 3800
-hotshoe
Well, this'll prolly stir up a hornets nest again - but - I went to Wallyworld today to get some oil for the ol' girl. All they carry now (at our store) is Rotella CJ-4, which is the "new" formulation. It actually has less ZDDP in it than the Castrol GTX 20-50w I've been using. According to the research I've done, you'll need to find the "old" CI-4 formulation to get more zinc than the Castrol GTX 20-50w.
Okay thanks everyone.
I know that the Rotella T15-40 is a Shell product but, who makes the GL-5 for the rearend and transmission ?
