| | | Forums66 Topics128,069 Posts1,055,890 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | The horns on my 6400 are mounted on the firewall with the relay underneath. The assembly manual show the horns mounted on the radiator support. But the drawing is dated 6-29-53 so it may not apply to a '49.There are no holes on my support to mount them. Can anyone with a '49 show me the correct location and horns, as these may not even be the correct ones. Picture below. Cleon http://inlinethumb06.webshots.com/38341/2060976230098468599S600x600Q85.jpg | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | They look correct and I've seen horns mounted there before. I've also seen them mounted on the manifold but that was a single horn. You have both a high and low note horn. Possibly this is where they go when it's optioned that way? Somebody smarter than me will let you know for sure.
Bruce | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Ok, It looks like some one lowered them by mounting them on a piece of flat stock and bolted them back up to the firewall in the original holes. I wonder why?. Maybe to clear the heater hoses? Thanks for the info. Cleon | | | | | Joined: Mar 2008 Posts: 28 Apprentice | | Apprentice Joined: Mar 2008 Posts: 28 | different horn(s) but same location as my '49 | | |
