3 members (klhansen, TooMany2count, Nick in Manitou), 194 guests, and 4 robots.
Topics128,089
Posts1,056,140
Members48,436
Anybody know what the specs are for the pressure plate to flywheel? I have a GMC 228.
I couldn't find a torque value in my GMC maintenance manual. All I could find is "...tighten gradually one turn at a time to compress spring evenly and prevent possible distortion of cover flange. Remove aligning arbor when bolts are tight."
In my Chevy manual it is listed at 45-55 ft/lb.
The only time I tried torquing clutch cover bolts I broke them off, I use a combination wrench about 5-6 inches long & my calibrated elbow(about as tight as you can get them w/said wrench). Make sure to tighten evenly as Cletis said. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
