| | | Forums66 Topics128,086 Posts1,056,098 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39719 03/04/2005 10:26 PM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | Anybody know what the specs are for the pressure plate to flywheel? I have a GMC 228. | | |
#39720 03/05/2005 3:06 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I couldn't find a torque value in my GMC maintenance manual. All I could find is "...tighten gradually one turn at a time to compress spring evenly and prevent possible distortion of cover flange. Remove aligning arbor when bolts are tight."
In my Chevy manual it is listed at 45-55 ft/lb. | | |
#39721 03/05/2005 3:59 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The only time I tried torquing clutch cover bolts I broke them off, I use a combination wrench about 5-6 inches long & my calibrated elbow(about as tight as you can get them w/said wrench). Make sure to tighten evenly as Cletis said. Brian | | |
