3 members (lumbersawyer, baldeagle, 1 invisible), 71 guests, and 3 robots.
Topics128,014
Posts1,055,332
Members48,419
#39698 01/31/2004 2:30 AM
U
U Offline
My engine block number is 2135412; how can I determine if it is a 248 or a 270 block?
ron
#39699 01/31/2004 2:48 AM
Buy a book on your truck or hope someone can give you the info.I think the manual is your best route in the long run For around $20 it will answer all your ???????'s
dan-pa
#39700 01/31/2004 3:34 AM
I
I Offline
On a GMC, the first 3 numbers on the flat machined surface on the block, just behind the distributor, will be the displacement of 228, 248, 270, and 302 motors.
#39701 01/31/2004 5:32 AM
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#39702 01/31/2004 5:36 AM
I have found the numbers at http://www.inliners.org/casting/numgame.html to be accurate. It shows that block only being used for the 270.
I agree the manual is a good inverstment, but I have never found them much good in trying to identify a motor.
