| | | Forums66 Topics128,102 Posts1,056,184 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 58 | Let the smoke out of the dash a few weeks ago. Looks like the heater switch was the culprit. I think somehow the wiper arm hit those coils. http://www.flickr.com/photos/22133917@N06/2380736267/sizes/l/ Question is, a replacement switch from classic parts looks more original, but still has those coils on top. http://www.classicparts.com/prodinfo.asp?number=68-322The one from Brothers looks much different. http://www.brotherstrucks.com/prodinfo.asp?number=HSW59DXI'd rather get the one from Brothers as it is covered. Anyone have experience with either? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The one I have is like the top one, about the only problems I've had is a lack of proper fan control, seems only to want to run on high. I do have one question for you. In the first pic, it looks like you have the controls mounted on the drivers side (I can see the ignition switch next to it). Did your truck come that way? All of the other Deluxe heaters I've ver seen have the controls on the passenger side. The position yours i in normally has the ash tray. Just curious.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the one from Classic Parts is the original style
I'm with Bill, looks like the control is in the wrong hole, and if any part of the wiper mechanism hit it that's why, but looks to me like the rheostat coil just failed and caused too much current draw
Bill | | | | | Joined: Dec 2007 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 58 | Nope, the heater control is on the passenger side. http://www.flickr.com/photos/22133917@N06/2132253128/sizes/l/ The switch was fine before the fire. It did run on low, but I would think that setting was pretty pointless as the fan did not move much air that way.
There is no bus or fuse box in the truck currently. The next major work aside from paint and body work is rewiring and adding a fuse box.
red58, I am going to paint it back to the original Cardinal Red like yours...unless I get the itch for a new color.
