1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39652 12/04/2003 5:56 AM | Joined: May 2003 Posts: 53 Member | | Member Joined: May 2003 Posts: 53 | I have a 56 GMC 500 series large truck,20 in. wheels with a 302 in it. I am looking to put a diesel engine into it and am looking for some suggestions on a motor and transmission combination that would work in this application. Anyone done this swap? any ideas would be helpful. Thanks Biddaboy :confused:  :rolleyes:
1956 GMC TF 1/2 ton 1955 GMC 500 model (Gumby)
#39653 12/04/2003 7:12 AM | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | Biddaboy, a 5.9 litre Cummins would be my choice. However my 41 will have a 6.2 litre up front, cause that's what I have sitting around. Mike | | |
#39654 12/05/2003 5:33 AM | Joined: Oct 2003 Posts: 54 Member | | Member Joined: Oct 2003 Posts: 54 | I would also agree with the Cummins. Haven't delt much with diesels, but I would think it would be easier to swap. I have a dream of someday building up a late 50's Chevy with a Cummins, but I don't know if I'll ever have the money to do it.  | | |
#39655 12/05/2003 5:48 AM | Joined: Oct 2003 Posts: 70 Member | | Member Joined: Oct 2003 Posts: 70 | Get out the wallet. worked for the city of L.A. one of the fuel tanks leaked after a big shaker, got water in the tank the only things that kept running Cummins. If I was going to do it I would look for old trash truck or so, eng. trans ,rad. aftercooler all ready running.We had L10 M11 654 allisons 754 and world.It dosent have be a trash truck, but they are sold for less | | |
#39656 12/05/2003 6:11 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I saw a 5.9 liter Cummins in a 1-ton Advance Design at a show in Shelton, WA. I wish I had taken some photos. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#39657 12/05/2003 11:41 PM | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | You looking for something that would be kinda stock, they put the 4-71 Detroits it those trucks back then.
Looking for something newer, well do just that, find a diesel powered truck, like a mid 80 size tilt cab.
Your best bet is to find a truck with envery thing you need, it will cost less in the long run and you know what to tell them at the parts house when you need to go for parts. | | |
