3 members (sron48, 1955 1 Series, Southerntruck), 37 guests, and 10 robots.
Topics128,010
Posts1,055,308
Members48,419
#393695 03/27/2008 12:04 AM
I recently pulled all the wires off the fuse blockbeing dumb as I was I forgot to write down where they go. Unfortunatly the fuse block lettering has faded so that makes it even harder to figure out. I have a wiring diagram from my shop manual, however it doesnt list what is what on the fuse block. Please help.
"you can't fix stupid"
captian_napalm #393713 03/27/2008 12:42 AM
what year?
Flxible #393838 03/27/2008 4:24 AM
66 with a L6 in it
captain
I just set up a photobucket so I hope this works. Try this link. I have a 1964 so it should be the same. So far it has not turned blue so at the worst you should be able to cut and paste. Eventually I will get it all worked out. If it doesn't work let me know.
http://s307.photobucket.com/albums/nn291/Rusty_1964/Electrical/
Rusty64 #395279 03/30/2008 7:54 AM
The 1964 and 1966 fuse blocks are the same.
Doug 57 #396466 04/01/2008 11:11 PM
this helps alot thank you very much
