5 members (TUTS 59, ‘37ChevyPU, Cosmo, 78buckshot, Ponchogl), 107 guests, and 2 robots.
Topics128,050
Posts1,055,674
#395348 03/30/2008 2:53 PM
Apprentice
Apprentice
Hey bolters,
I have a 39 GMC, 228 with the orginal Zenith caburetor. When the engine is hot, 180 degrees, the engine floods.
This will happen about 10-15 minutes after the engine is shutdown. I varified this by waiting and looking down the carb.
The engine is timmed correctly and has a steady 18 inches of vacuum at idle.
How can I solve this percolation problem?
Thanks, Jim
Jim
Jim,
I missed class the day they studied '39 GMC's, but most old Chevrolet's has a phenolic spacer located between the manifold and carburetor to act as a thermal insulator.
This kept heat from crawling up and doing exactly what you describe. Does your truck have one of these insulators under the carburetor?
Stuart
Apprentice
Apprentice
Stuart,
I do have an insulator block. I was also thinking, perhaps the float is too high.
The carb was professionally rebuilt and the truck runs great. So I'm not sure about changing the float level.
Thanks for your input,
Jim
Does your heat riser valve work? It could be just a flooding carb and I guess in that situation, full throttle position is the way to clear it until it starts.
1951 1 Ton Completed
Apprentice
Apprentice
E. Gabster
The heat riser valve works good.
To get it started after sets awhile is to keep the throttle full open.
Thanks, Jim
Jim
Ex Hall Monitor
Ex Hall Monitor
I had a hard starting hot problem. The solution was a combination of things. High amp battery (Optima Redtop 6v), 1 gauge cables (no body had 0 gauge) and learning to not step on the gas pedal when starting hot. They all have some heat transfer because of the way the manifolds are made so there's a tendency for a carb to percolate some. Stepping on the gas pedal only squirts more gas into a rich condition. It usually only takes a few seconds of cranking when hot to fire up now.
I also had a hard starting problem when hot. Increased the gauge of the battery cables to heavy duty to the starter. No more problems. Didn't seem to be associated with the crappy Rochester.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
Scroll down this page until you see the "hard starting-hot " paragraph. Also look and see if your fuel line is making contact with a heater hose.
http://www.thecarburetorshop.com/Troubleshooting.htm
You Tube
Apprentice
Apprentice
Thanks for the info on the gasoline. I will try to start the engie using that method.
No, the gas line does not touch any hoses, and clears the engine block.
Jim
