0 members (), 171 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
Y
Y Offline
To check operation of fuel gauge? TIA
Don't know if there's a "easy" way to do it, but this is one of the most popular topics on this site. You might go to the electrical department and do a search. You'll be overwhelmed with what you discover.
Is your gauge working at all? If not then you might want to look at the grounding points for both the gauge as well as the sending unit. This is one of the most common reasons for a gauge to not work (assuming 12 volts have not been introduced directly to the gauge). Do a search and see what you come up with.
Craig
The gauge can be checked as follows:
With the ignition on:
1. Disconnect the lead from the sender. The gauge should peg out at the "full" end of the gauge.
2. Ground the lead from the sender. The gauge should read close to "empty.
