Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (cmayna, Jaison, Wayne67vert, Youngin' Tut 59), 42 guests, and 5 robots.
Topics128,010
Posts1,055,305
Members48,419
#3950 01/20/2003 11:29 PM
I'm having trouble with my '46, 216, with a carter w-1 carb. It's hard to start unless it's already hot or warm. I put a vacuum gauge on it and it reads normal. When I screw in the idle adjustment needle all the way the engine doesn't die, it does stumble a bit but doesn't die like I'd expect. It'll start cold sometimes when I prime the carb with a little chainsaw gas. Also, I can't get it to idle down. I don't think there's a vacuum leak. Any help or suggestions appreciated. Jacques
Union, Justice and Confidence
#3951 01/21/2003 1:27 AM
Check your timing and dwell. Mine gets hard to start when it is off.
Paint & Body Shop moderator
#3952 01/21/2003 2:41 AM
Float level ??
Worn throttle shafts ?
Fuel pump valves leaking fuel back ?
Basics ,, plugs and points ?
#3953 01/21/2003 4:25 AM
My distributor wobbles when the engine is running. Could that throw it off enough? It runs well once I get going, 4th on the floor. Dusty, I rebuilt the carb and the throttle shaft seems pretty tight to me. The bellcrank(?) on the end of the shaft is a little loose. It's got new pts, wires and condenser. Plugs look good, but you make me wonder about 'em. The old books I've got talk a lot about selecting the right plugs. Do you think that's something to look into such as a hotter plug? Thansk, Jacques
#3954 01/21/2003 4:42 AM
Sounds to me like you have a choke problem. You might check that out.
#3955 01/21/2003 4:53 PM
Carb related for sure. Its an old V8 tuning trick: If the engine is idling with choke off, and you close down your idle mixture screw it should die. If not she's running too rich or has another carb problem.
Check float level, accel pump shot, loose main jet, needle valve, etc.
good luck
chip
BTW, where is Jeanerette? I grew up in Hammond, me. grin
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#3956 01/22/2003 1:38 AM
Thanks for the input, guys. Chiphead, what you said about the carb makes me wonder if the needle wasn't closing all the way with the engine not running, would it drain the fuel from the bowl. Maybe, then, it would take a while for the bowl to fill up again when trying to start after it's sat a while. BTW, Jeanerette is about 30 miles S of Lafayette, on Hwy 90. I've been to Hammond a few times in my "carefree" days...nice town! Thanks, Jacques
#3957 02/10/2003 1:41 AM
Thanks for all the input, guys. I think I've got the problem licked. I re-rebuilt the carb and that seems to have done it. I guess I was too much in a hurry the first time and didn't do it right. The float was set way too high, there was a blocked passage and more crud in the bowl. Also, the main nozzle that points up at about a 45 deg angle into the venturi wasn't put in right. The real test will be to see how easy it starts after sitting a day or two. Today it started easily and ran great. Thanks again, Jacques
#3958 02/10/2003 2:22 AM
Thanks for posting the end of the story. Lots of times we hear what the trouble is but never the solution...
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
