7 members (Peggy M, cmayna, 49choptop, baldeagle, fonz8261, FrankenChevy, 1 invisible),
59
Mod | | | Forums66 Topics128,018 Posts1,055,341 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39562 04/23/2002 2:11 PM | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | anybody know if the differential from a later model diff from a gm 1 1/2 ton with a 10 bolt pattern will fit under a 51 1 1/2 ton with a 10 bolt pattern, 2 spd.? trying to get a higher ratio, and get away from the 2 speed. i think the bolt patterns are the same, so i can use the stock wheels. 48 mph top end ain't gonna get it, especially since the speed limit in front of my house is 55---and everybody goes 65. | | |
