0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 8 New Guy | | New Guy Joined: Sep 2007 Posts: 8 | I just pulled the fuel tank from my 59 Apache and discovered that the L-shaped reinforcement brackets where the cab mounts to the frame needs to be replaced. These are the brackets inside the cab that the bolts go through and that bends 90 degrees up the rear cab wall. They are cracked from stress and rusted. Does anyone know if these are available new? I haven't been able to find them at any of the vendors I usually buy from. Any help appreciated.
1959 Apache Fleetside Deluxe
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I've never seen them anywhere, I think you're looking at fabbing them or getting someone to pull them out of a parts cab
Bill | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Fab your own. Take some 3/16 steel and heat it to 90 degree and add a little reinforcement and you'll have it stronger than original.
~Jim
