| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39551 10/08/2004 3:29 AM | Joined: May 2003 Posts: 18 Junior Member | | Junior Member Joined: May 2003 Posts: 18 | I am having trouble deciding what ratios will be best for my truck. Im running a stock 235 and a 3/4 ton rear converted to 4.10. I will never be hauling or towing anything in this truck; it wiil be a daily driver and spend a lot of time on the highway. I am considering a S10 tranny with 3.76 first and a .72 overdrive. This should put me at a little under 2200 rmp @ 70 with my 31.7 inch tall tires. I was wondering if there are any ratios that I should stay away from, besides an .86 overdrive unit? Which ones will give me a good balance between take-off and high way speeds? | | |
#39552 10/08/2004 5:13 AM | Joined: May 2004 Posts: 62 Member | | Member Joined: May 2004 Posts: 62 | Your choice of T-5 is good. The other ratio tranmission would do well also.
Just be sure it is from a truck, S10 or Isuzu so that the shift tower is in the most forward position. The cars have the shift tower toward the end of the tail shaft (between the bucket seats). They work but interfere with bench seats.
Look at the speedo drive. 82-88's are mechanical. 89-95's are electronic.
47 Fleetmaster, Hotrod 6, 5 Speed 50 Sedan Delivery, 327, 5 Speed
#39553 10/09/2004 5:06 AM | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | You can get a camaro tranny and get some better gears. i.e. better tack off and better highway. And just bolt on a s-10 tail shaf. I work in a hotrod shop and we do it all the time. | | |
