4 members (Hanks custodian, klhansen, Peggy M, 1 invisible), 123 guests, and 2 robots.
Topics128,052
Posts1,055,727
Hello,
My front and rear axle seals are leaking and need some help to find where I can get them.
Also I need alignment specs.
Truck is a 1959 GMC Napco 1/2ton p/u.
Here's what I need for seals;
Front-
inner axle shaft seals.
steering ball seals(large).
steering ball seals(small).
steering ball gaskets.
spindle bushings.
Rear-(this is a 1960-62 Chevy Dana detroit gear & axle 1/2ton)-
axle seals.
cover gasket.
Thank you,
Bob
There is a NAPCO owner's group out there, check the links page or run a search on Google. They should be able to tell you what you need to know.
Update: here is the link. NAPCO
1954 GMC De Luxe COE
