| | | Forums66 Topics128,037 Posts1,055,469 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39549 05/14/2003 3:56 AM | Joined: Jun 2002 Posts: 53 Member | | Member Joined: Jun 2002 Posts: 53 | Hello, My front and rear axle seals are leaking and need some help to find where I can get them. Also I need alignment specs. Truck is a 1959 GMC Napco 1/2ton p/u. Here's what I need for seals; Front- inner axle shaft seals. steering ball seals(large). steering ball seals(small). steering ball gaskets. spindle bushings.
Rear-(this is a 1960-62 Chevy Dana detroit gear & axle 1/2ton)- axle seals. cover gasket.
Thank you, Bob | | |
#39550 05/14/2003 5:52 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | There is a NAPCO owner's group out there, check the links page or run a search on Google. They should be able to tell you what you need to know. Update: here is the link. NAPCO | | |
