3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
I just pulled the fuel tank from my 59 Apache and discovered that the L-shaped reinforcement brackets where the cab mounts to the frame needs to be replaced. These are the brackets inside the cab that the bolts go through and that bends 90 degrees up the rear cab wall. They are cracked from stress and rusted.
Does anyone know if these are available new? I haven't been able to find them at any of the vendors I usually buy from.
Any help appreciated.
1959 Apache Fleetside Deluxe
I've never seen them anywhere, I think you're looking at fabbing them or getting someone to pull them out of a parts cab
Fab your own. Take some 3/16 steel and heat it to 90 degree and add a little reinforcement and you'll have it stronger than original.
~Jim
